FTP backups - a safer option
Author: Debbie Grignani, 2BrightSparks Pte. Ltd.
The most important task after backing up your data is to ensure that the backups are stored safely, preferably offsite. You could physically move backup media, for example tapes and CDs/DVDs, to offsite locations. This can often prove to be tedious, time consuming, inconvenient and unreliable. A simpler solution is backing up to a server that is kept offsite via FTP.
What is FTP?
File Transfer Protocol (FTP) is a language used for transferring files from computer to computer across the Internet. FTP alone is not secure, and it is advisable to encrypt files before the transfer. That is the reason why there are FTP protocols like SFTP and FTPS. Although relatively few FTP servers support these secure protocols, it is good to be informed about them.
What is SFTP?
SFTP, or Secure FTP, is a program that uses a secure shell (SSH) to transfer data files. SSH is a network protocol that allows for the secure exchange of data between computers. Therefore with SFTP, commands and data are both encrypted thus preventing passwords and other sensitive information from being transmitted in readable form over the network.
SFTP uses a different protocol to standard FTP, therefore an FTP client is unable to communicate with an SFTP server. Similarly, an FTP server will not be able to connect to a client that only supports SFTP. A common misconception is that SFTP is FTP run over SSH, and that it is also sometimes confused with Simple File Transfer Protocol, an unsecured file transfer protocol.
Besides providing encryption via a secure channel, SFTP also provides a way to authenticate both the user and host.
What is FTPS?
FTPS (commonly referred to as FTP/SSL) is FTP with the added option of Secure Socket Layer (SSL) security, where SSL allows data to be transmitted via the Internet securely. In other words, FTPS is a standard FTP software in which SSL is used to secure the control and data connection. Each way involves the use of an SSL/TLS layer below the standard FTP protocol to encrypt the control and/or data channels. It should not be confused with SSH file transfer protocol, or FTP over SSH. Transport Layer Security (TLS) and its predecessor, Secure Sockets Layer (SSL), are cryptographic protocols which provide secure communications over the Internet.
And what is FTP over SSH ?
FTP over SSH refers to the practice of “tunnelling” a normal FTP session over an SSH (secure shell) connection.
Backup Software that support FTP backups
There are several backup software programs on the market that support FTP backups. 2BrightSparks carries three different options of backup software that support FTP backups. They include SyncBackFree, SyncBackSE and SyncBackPro. As far as FTP capabilities go, SyncBackSE has a much higher performance compared to SyncBackFree. All three provide encryption options and therefore allow for added security of data files with just standard FTP backups. SyncBackSE supports FTPS as well, while SyncBackPro supports SFTP backups and BZip2 compression that has a better compression rate than Zip, therefore being able to speed up the backup process.
V12 FTP and SFTP Improvements
SyncBack V12 introduces several improvements for FTP and SFTP backups:
  • TLS 1.3 for FTPS: SyncBackPro and SyncBackSE now support TLS 1.3 with the Eldos FTPS engine, providing the latest and most secure version of the TLS protocol for encrypted FTP connections.
  • Parallel chunked SFTP transfers: SyncBackPro and SyncBackSE can now download and upload files in chunks in parallel over SFTP using Worker Threads. This can significantly improve transfer speeds, especially for large files.
  • Basic AUTH for HTTP downloads: SyncBack V12 supports Basic AUTH (e.g. http://username:[email protected]/) for HTTP downloads and FTP HTTP downloads, making it easier to download files from authenticated web servers.
For more details on secure FTP connections, see our Transfer Encryption and SFTP articles.
So remember: backing up your data files is important, but you also need to think about keeping those backups safe. In the event you need to restore your data, your backups have to be easily accessible. FTP backups are an ideal solution.
