Backup Data and Apps?
neil154
Post by neil154 » Sun Sep 18, 2016 12:10 am
I would like to know if Syncback Touch backs up only data files or will it also back up my apps on my Android phone
Re: Backup Data and Apps?
Post by Swapna » Sun Sep 18, 2016 3:14 am
SyncBack Touch supports backing-up files/folders created by the user or the files that user has access to. For example: user's photos, music, videos etc., It does not support backing-up system files, apps, calendars or contacts due to access restrictions. Also there isn't any real benefit trying to back up such files as they will not function as you expect, when you restore them.
neil154
Post by neil154 » Sun Sep 18, 2016 3:21 am
Thanks for the quick response, I suspected that would be the answer but was hoping otherwise
