Infinite recursion on Android 6.0.1
Bassflute
Postby Bassflute » Tue Aug 30, 2016 8:42 am
Hi!
I tried to set up an Android backup with SyncBack Touch for the first time today.
I left the file filter as standard, but my simulated run resulted in a recursive loop, apparently in a folder to do with drivers.
Is there any way I can get a log file to post? And what might be the problem?
Cheers,
Ed
Re: Infinite recursion on Android 6.0.1
Postby Kostas » Tue Aug 30, 2016 8:59 am
Can you tell us the paths you are using as source and destination?
Return to “SyncBack Touch”
