Sync back Touch very slow
swordfish
Postby swordfish » Mon Dec 28, 2015 9:00 pm
Have been using Syncback SE for many years - great product.
Recently began using Syncback Touch to back up items held on an iMac (running OSX El Capital) to my main PC (Windows 10 64). The Mac is running Syncback Touch v 1.0.30.0.
For the first ten minutes in running the backup everything is fine - Syncback reports transfer speeds of up to 8Mbps and the entire backup is estimated to complete in a few hours (it's the first backup for a large number of photos). However, when the ten minute mark is reached (in terms of time the backup is running - not the amount of time Syncback Touch or Syncback is running) the process slows to a crawl and the estimated time to complete blows out to something like 6 days.
Strangely, restarting the backup process has no effect - it continues to crawl. Restarting Syncback Touch Syncback SE gets things working again - but only for 10 minutes.
I've tried changing options in Syncback SE (turned off verify etc) and on the firewall on both the Mac and PC with no luck. Can anyone else suggest something to try? Would appreciate any help!
Re: Sync back Touch very slow
Postby Kostas » Tue Dec 29, 2015 6:10 am
Can you tell us approximately how many files are you trying to copy via SyncBack Touch so we can try and run some tests at our side?
I assume you are trying to copy across a local area network? Are both ends (SyncBackSE and Touch) on wired connections, wireless or mixed?
swordfish
Postby swordfish » Tue Dec 29, 2015 12:23 pm
Hi Kostas,
yes, I'm copying across a LAN - both the PC and the Mac are connected by ethernet. There are a large number of files - about 17,000 in total, but no more than a few hundred are copied before the problem sets it.
Postby Kostas » Wed Dec 30, 2015 6:39 am
Did a test today with approx. 6000 files (image and audio files) over a wireless router and had an average speed of 3.5 MB/s. I didn't experience anything like you did. Maybe you can try disabling any firewalls and AV software you may have on both sides and try again to see if it makes any difference?
PeterBrockie
Postby PeterBrockie » Mon Mar 13, 2017 6:24 pm
I'm having a similar issue over 1GbE. Transferring from my Sierra based Mac to my FreeNAS server (via Windows 10 SyncBackPro).
Everything is the latest version. It starts off at around 50 MB/sec* and after a while it drops to only a couple hundred kilobytes per second. Restarting it resumes to 50 MB/sec, but it drops again. I have two drives (OS, Final Cut Pro videos) on the Mac and two backups. Both show the same behavior.
*50 MB/sec is half speed. Everything on my network is full duplex, 1 Gbit. I don't know why it starts so slow. It should be able to push a little over 100 MB/sec.
Postby Kostas » Mon Mar 13, 2017 10:49 pm
PeterBrockie wrote:I'm having a similar issue over 1GbE. Transferring from my Sierra based Mac to my FreeNAS server (via Windows 10 SyncBackPro).
I suggest submitting a support ticket for your profile by using the Contact Support in the below link in this article and attach the zip file.
Return to “SyncBack Touch”
