Exit app when profile has been finished
Sasa
Postby Sasa » Sun Sep 27, 2015 9:39 pm
An option to automatically exit SyncBack Touch on the device after a profile has been finished would be nice.
BTW it runs stable and smooth (tested on Samsung S5 Mini, HTC One Mini and One M8s; stock and custom ROMs/CWM), thanks!
Re: Exit app when profile has been finished
Postby Kostas » Mon Sep 28, 2015 7:19 am
Thank you for your feedback. You suggestion will be considered during our technical review but we can't promise if or when this feature will be added.
Sasa
Postby Sasa » Mon Sep 28, 2015 8:29 am
Thanks.
For exiting manually I also would suggest an option to deactivate the confirmation dialogue within the settings (or that it only appears when a profile is running - if that is possible). And maybe placing the exit-button/cross (or complete menu-items) within the main window would make sense... in my daily usage I've noticed that this simply would enhance the workflow.
Return to “SyncBack Touch”
