Files are only copied not moved
olidie
Knowledgeable
Knowledgeable
Post by olidie » Mon Sep 07, 2015 11:39 am
I am using SyncBack Touch to backup certain picture files (.dng) from my phone (Nexus 5, Android 5.1.1) to my PC (Win 8.1 x64, Syncback Pro v7.3.4.0). The profile is setup to move the files from the phone to the computer "Files only on NEXUS are moved to Destination". This used to work fine but not anymore although nothing was changed. Files are just copied and remain on the phone.
Any ideas what the problem might be and how to solve it?
Thank you in advance
Oliver
Re: Files are only copied not moved
Post by Kostas » Tue Sep 08, 2015 1:06 am
You may need to generate a Support Zip with debug log for your profile and send it over to us for investigation.
olidie
Knowledgeable
Knowledgeable
Post by olidie » Tue Sep 08, 2015 6:17 am
Thank you Kostas. I uploaded the debug log to your support.
Oliver
olidie
Knowledgeable
Knowledgeable
Post by olidie » Tue Sep 15, 2015 6:59 am
Hello Kostas,
as advised I submitted a debug log on Sept 8th and haven't heard anything since then. Any ideas?
Oliver
Post by Kostas » Tue Sep 15, 2015 7:02 am
Hi Oliver,
A reply was sent to you the same day. Maybe the email landed in your spam/junk email folder?
olidie
Knowledgeable
Knowledgeable
Post by olidie » Tue Sep 15, 2015 7:06 am
I just checked my spamfolder but it seems to contain only messages newer than 6 days. Can you pleas resend it? Thank you!
Post by Kostas » Tue Sep 15, 2015 7:13 am
I just did :)
olidie
Knowledgeable
Knowledgeable
Post by olidie » Tue Sep 15, 2015 7:29 am
Thank you. I just replied to your email.
It seems like android did not update the file/folder quickly enough for the windows explorer not to see the deleted files. After restarting the phone the files were completely gone.
