Reset password SyncBack Touch on Mac
christianschneider
Post by christianschneider » Sun Jul 26, 2015 9:06 am
i forgot my SyncBack Touch password on the Mac.
On the Settings-Menu there is no option to reset the password.
How do I reset the password on the Mac?
Mirko
Re: Reset password SyncBack Touch on Mac
Post by Kostas » Sun Jul 26, 2015 1:41 pm
I would suggest uninstalling and re-installing the application as there is no mechanism resetting/removing the password if you have forgotten it.
You can download SyncBack Touch for Mac OSX from http://www.2brightsparks.com/assets/sof ... kTouch.dmg
If you still have problems after doing the above please contact support@2brightsparks.com
christianschneider
Post by christianschneider » Sun Jul 26, 2015 3:33 pm
Thanks Kostas,
I tried to uninstall and reinstall (remove from Mac-Apps-Folder and re-install) but I'm still being asked for the password.
I'll ask the support team.
Thanks anyway,
Mirko
