Prevent Closing app on Mac OSX
cobbcobb
Post by cobbcobb » Mon May 04, 2015 7:35 pm
We've been having issues syncing from a PC to Mac OSX computers with Sync Back Pro. As it turns out if we install SyncBack Touch on the Mac OSX computers then we are able to sync without problems. However, the syncback touch does not run in the background and instead is launched as a separate app window. I'm concerned that if someone inadvertently closes the app then we will not be able to sync. Is there any way to prevent SyncBack Touch from being closed on the Mac?
Thank you for your help!
Re: Prevent Closing app on Mac OSX
Post by mickyj » Tue May 05, 2015 3:43 am
Hi, sorry, but SyncBack Touch doesn't run in the background on OS X (unlike Windows). There is no way to stop SyncBack Touch from being closed by a user.
