I'm using V9.3.30 under Windows 7 64 bits. I've programmed the software to go through a mirror operation every 30 minutes (every day, repeat every 30 minutes). It works perfectly as long as I'm up and running.
After a shut down and reboot, the "Next execution" shows up as Unknown. Even when it's the same day. I did tick the option "Execute this task as soon as possible after a miss".
This error is new for me. I've been running the product for years without a hitch.
scheduled run time switched to UNKNOWN
Re: scheduled run time switched to UNKNOWN
Thanks to all of you who reviewed this post and did not deign to offer a suggestion. I found a solution after all.
yeesh, I just posted a question then looked down the list to see yours. 750 views and no replies! Glad you figured it out.
