I started another thread about my servers having a strange behavior when backing up. Well I found another one and this is not good. What I found on another computer is that the source files are left intact, but the destination files get deleted. The settings are these in the decision-files tab
1 - Source overwrites Destination always (backup)
2 - Copy file to Destination
3 - Delete file from Destination if it hasn't been modified within the last 0 days
4 - Do nothing
How I found this is when i looked at the backup computer, the folder had no files. The source has files and should be backing up based on the above settings. Under the Compare Options I unchecked the "Skip the Differences......" and then when I ran the backup I saw that the log was going to delete everything on the destination side. I proceeded the process only to watch Syncback delete all the files at the Destination, but left my files at the Source.
This does not make any sense based on the settings.
In version 8 these are the same settings and it worked flawlessly, so based on the above information, what other setting is Syncback needing to be added or changed that is not straight forward?
Also, when in Simple mode I can see an instruction "Files only on Destination are deleted". I think this is the problem, but then another is discovered. Changing this to "Backup Source to Destination" does not work either. No files are copied.
Any help is greatly appreciated.
And yet another issue discovered; not copying
- Enthusiastic
- Enthusiastic
Re: And yet another issue discovered; not copying
UPDATE - so checking all the settings against other computers it all matches so not sure why Syncback is deleting the files. There is definitely something wrong in the code as my other thread proved that using the older versions the problem does not exist. So I am chaulking this one up as the code is wrong in Syncback and that version 9.3.11.0 needs to be patched. I am basing this off of the results that i have tested and another member here tested as well and saw the issue.
Will roll back and wait for another patch
I guess it is a similar issue as I currently have?
viewtopic.php?f=29&t=14275
