run profile via ssh
nikc
run profile via ssh
Post by nikc »
Hello
I am trying to run a SyncbackFree profile on Windows 10 via ssh from a machine running Linux.
The ssh command I am using on the Linux machine is this -
Code: Select all
ssh [email protected] "D:\Users\john\sync.bat"
The contents of 'sync.bat' on the Windows machine is this -
Code: Select all
@echo off
"D:\Program Files (x86)\2BrightSparks\SyncBackFree\SyncBackFree.exe" sync
ssh [email protected] /home/nick/complete.sh
The profile does appear to run however the 'Results' column in Syncback then displays 'Network Failure' on completion. The batch does complete as the last line executes successfully.
Is there a way I can get this to work as intended or is it the case that what I am tying to do is not possible?
Many thanks
