I would like to know if possibly to make a backup this way:
- Source: *.JPGs from multiple folders all having subfolders and from a common root folder. This part should be easy by specifying filter like *\ and *.jpg
- Destination: ONLY one folder. I don't mind if the origin has 1000 folders. I need all the JPEGs in a unique folder containing the 24.000 jpgs. No further folder structure needed.
What would be the option to set of configure? I cannot make it happen.. it always respects the folder structure from origin.
Thanks in advance!
How to copy recursive folders but to only one folder?
Re: How to copy recursive folders but to only one folder?
This is exactly what I was looking to do. Flattening the structure looks not supported.
Thanks for the prompt answer
