How to backup to a computer in my LAN.
suwosuwo
Post by suwosuwo » Thu Nov 23, 2017 12:51 pm
Hi
this is a lame question perhaps, i don't have almost any experience in LAN
i wanted to make a weekly backup of a folder on my comp to a folder on an other comp in my LAN.
But if I choose \\OTHERCOMPNAME in the destination, Syncback says it can't connect and i need to choose other location.
Re: How to backup to a computer in my LAN.
Post by cliffhanger » Sat Nov 25, 2017 11:36 am
Sounds like you haven't yet created any Shares on the 'remote' machine (and/or, you haven't configured any security for the Shares), so your remote PC is 'visible' on the LAN, but not 'internally reachable' (you can't see any of its folders or files, because you haven't configured which ones should be accessible, and 'to which user account'). If you double-click on the remote machine in the network section of Windows Explorer and don't get a list of shared resources (you get an error instead), this is probably why. You need to set up Sharing and Security on the machine you hope to read/write over the network (so you can manually read/write/delete files on it remotely before trying to automate that using SB)
This old article has some details how to do so for a couple of versions of Windows, but if they don't match yours, there are plenty of other how-to-network-Windows resources on the web Bear in mind this is a Windows issue till you get networking set up so that it works manually.
Note: the KB article I linked to mentions Touch, which is a very handy alternative to the above & sidesteps a lot of the work involved (you don't need to set up sharing, and Touch avoids most Access Denied issues by running under the local SYSTEM account). However, Touch does not work with SB Free (or Lite), only with SE or Pro. You get 2 free Touch installs with a single SE or Pro license, and obviously other benefits accrue with the commercial versions also.
Post by cliffhanger » Sat Nov 25, 2017 6:38 pm
PS it just occurred to me that when you say
suwosuwo wrote:...if I choose \\OTHERCOMPNAME in the destination, Syncback says it can't connect and i need to choose other location
it is not 100% clear how you are 'choosing' it.
  • If you 'chose it' by simply typing in the \\MACHINENAME you will get that error, yes (see previous reply for why).
  • If you try to do it by browsing to it (in SB) and you simply select (highlight) that PC on the network and then click Select Folder, it will error, yes. But if you double-click that PC (machine name) and it drills down into one or more 'folders' (these are the shares on that remote PC, if you have any configured), you can choose one of the shares, and it shouldn't error when you click Select Folder.
  • If you are browsing to it in SB and try double-clicking the machine name (PC) and it does not 'drill down' into one or more shares, that is presumably because you don't have any shares set up yet on the other PC (in which case, see previous reply).
