Backup tracking (SyncBackFree V8.3.6.0
alainjjb
Postby alainjjb » Wed Nov 08, 2017 10:38 am
Sorry for my poor English :oops: .
I have a problem with my backup tracking. I have to refresh it to have the right dates :cry: .
What should I do for this refresh to be done automatically ? :?:
thank you in advance for your help
Alain
Re: Backup tracking (SyncBackFree V8.3.6.0
Postby Swapna » Thu Nov 09, 2017 12:37 am
Can you please let us know the version of Windows you are using? Also, please post a screenshot of the dates that are not updated automatically?
alainjjb
Postby alainjjb » Thu Nov 09, 2017 8:42 am
thank you for your reply.
the windows version is 7.
alainjjb
Postby alainjjb » Thu Nov 09, 2017 8:53 am
I start adding the image that did not work. Hoping ...
http://www.cjoint.com/c/GKjiNgef1DL
alainjjb
Postby alainjjb » Thu Nov 09, 2017 10:12 am
Useful information ? :
I did a test by manually executing the task (unattended) and the tracking is updated.
The problem is therefore related to the planning of the task.
Thank
Postby Swapna » Thu Nov 09, 2017 10:58 am
First, please upgrade to the latest version of SyncBackFree (V8.3.16.0) from here:
After upgrading, configure the schedule task to run only when the user is logged-in (tick the option 'Run only when user is logged on' under: Modify > When > Edit Schedule > Security tab) and check if the last run, next run and result columns are updated? If it works, and if the problem occurs only when the schedule task is configured to run whether the user is logged-in or not, then it could be related to new security changes in Windows. Please read this form post for more details:
viewtopic.php?t=12667&p=48197#p48197
So, you may need to press F5 to refresh the display.
alainjjb
Postby alainjjb » Thu Nov 09, 2017 12:41 pm
It's OK !
I updated SyncBackFree with the latest version (V8.3.16.0) and change the configuration of the task schedule "Option: run only when the user is logged-in".
After a scheduled execution test the dates are up to date.
Thank you very much Swapna =D>
Alain
Return to “SyncBackFree (freeware)”
