Correct "cannot connect to destination"?
gogreen
Experienced
Experienced
Post by gogreen » Tue Nov 07, 2017 8:10 pm
I recently did a repair installation of Windows 10 on my laptop, and now when I try to sync folders between my desktop and laptop, I get the attached error message. I can sync just fine to two other shared folders, but this message appears for all the other folders that used to sync just fine. Did I miss a file setting?
Re: Correct "cannot connect to destination"?
Post by Swapna » Wed Nov 08, 2017 2:03 am
"The network path was not found" is a Windows error (not a SyncBackFree error). Our program is just reporting the error back to the user. You can refer to that Windows error code here (search for code 53):
https://msdn.microsoft.com/en-us/librar ... S.85).aspx
Can you try connecting to your network drive (using the UNC path entered in the profile) from the File explorer (or Windows explorer) to see if it works? If yes, then try these suggestions:
1. Reboot both Source and Destination computers
2. Ensure the you have entered correct credentials to connect to your network drive under:
Modify > Expert > Network settings page
3. Enable the option "Use the supplied username and password before trying my current username and password" under:
Modify > Expert > Network > Advanced settings page.
4. Try entering the I.P Address instead of the hostname in the UNC path to connect to your network drive and retry the execution.
gogreen
Experienced
Experienced
Post by gogreen » Wed Nov 08, 2017 1:49 pm
Thanks, Swapna. I'll try this later today.
