password to start the program
marcos052110120
Post by marcos052110120 » Thu Oct 05, 2017 4:15 pm
a question will have way to put password to start the program
Re: password to start the program
Post by cliffhanger » Sun Oct 08, 2017 11:30 am
It is not 100% clear what you are asking for/about, but if you are hoping for an option where you must enter a password before you can run SB, then that is not supported. There is a profile-level option to require that a password be provided before a user is permitted to modify or delete a profile, but not for running the profile 'as it is', nor for running the program itself.
