How to order profile groups?
1DumSpark
Experienced
Experienced
Post by 1DumSpark » Mon Aug 15, 2016 10:09 am
How does one order the profile groups? Note that I'm referring to ordering the groups themselves, and not the profiles within them.
Currently, one can prefix each group name with a number so that they will be ordered as desired... but I can't help but think I'm overlooking something more obvious.
Re: How to order profile groups?
Post by Swapna » Tue Aug 16, 2016 8:11 am
You can click on the 'Profile' column header (from SyncBackFree's main-interface) to sort the Profiles and Group profiles in ascending or descending order. However, sorting is applicable only to the main group profile in the list. That means the member profiles in the group or nested groups are not sorted.
Cannondale
Post by Cannondale » Sun Sep 17, 2017 6:12 pm
I agree that the ability to change the order of profile groups on the main syncback interface page is a missing feature. Drag and drop would be perfect addition. However, as a workaround I created a dummy group and called it _Syncback, which sorts to the very top of the group list.
Then I added ALL groups to this dummy group (_Syncback) and sorted the groups, that _Syncback contained, as usual with the up/down arrows on the right side of the dialog box.
