User aborted or the profile run-time limit was reached
tis1980
Postby tis1980 » Fri Feb 05, 2016 7:27 am
I'm trying to do a backup of my files to a network share. I've done it a million times before, but now it suddenly stopped working.
User rights and network settings are fine, so I don't understand why this error suddenly occurs? :?
/Allan
Blaeul
Re: User aborted or the profile run-time limit was reached
Postby Blaeul » Thu Mar 23, 2017 8:34 am
Dear 2BrightSparks team,
This is still an issue in SyncBackPro V6.5.49.0. We have a number of planned tasks that start SyncBack groups. The following log is from one of the group member profiles.
I couldn't find a time limit anywhere in the settings of either Windows or SyncBackPro. No human stopped the profile.
What can I do? It seems similar to https://www.2brightsparks.com/bb/viewtopic.php?t=10383
vernzimm
Postby vernzimm » Tue Nov 28, 2017 3:20 pm
Hi All,
Is there a solution to this? I am having the same problem in v8.4.5.0. I have about 20 profiles set up, and only two have this issue (they are all basically copies). I ran debug and here is the log (file paths have been scrubbed) Something about "insert disk", but that makes no sense. It is saved to a network share...
Code: Select all
10:05:36=Profile Filename:C:\Users\ \AppData\Local\2BrightSparks\SyncBackFree\03 mCosmos partial past week_Settings.ini
10:05:36=Settings Filename:C:\Users\ \AppData\Local\2BrightSparks\SyncBackFree\Settings.ini
10:05:36=---:System [28-Nov-17 10:05:36 AM
SyncBackFree V8.4.5.0
Windows 7 x64 Service Pack 1 build 7601 (6.1.7601) (English) (Unknown)
Prev Win   = Windows 7 x64 Service Pack 1 build 7601 (6.1.7601) (Unknown) , 28-Jul-17 12:00:07 AM
Cur/Prev V = 8.4.5.0 , 8.3.16.0
Cur/Prev DT= 20-Nov-17 4:09:39 PM , 10-Nov-17 1:14:31 PM
Memory     = 4135/8114 MB (free/total)
Allocated  = 126.07 MB
Display    = 1920x1080, 32 bit (2)
Sys Uptime = 13 days 1 hour
Prog Uptime= 2 hours 5 minutes
CPU        = Intel(R) Xeon(R) CPU E5-1603 v3 @ 2.80GHz
CPU count  = 4
Admin      = -1
GUI        = 268/286/10000
Temp Folder= C:\TEMP\
Temp Free  = 421335302144
Username   = M3C\m3c
IsInWrkgrp = REESE
SessionID  = 8
ActSessID  = 8
Filename   = C:\Program Files (x86)\2BrightSparks\SyncBackFree\SyncBackFree.exe
ParentProc = C:\Windows\System32\taskeng.exe
No Desktop = 0
VM/VP/BP/WI= 0/0/0/0
TS         = 0
External   = 0
WinExternal= 0
Debug      = 0
DOP        = NS
GW         = Y
GMT Bias   = 300
EHV        = A7D8E446B7DF609963E134D7CD8C1122
CS         = 13A6344DB52D45D8F93913245D801094
Environment=
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\ \AppData\Roaming
CommonProgramFiles=C:\Program Files (x86)\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=M3C
ComSpec=C:\Windows\system32\cmd.exe
DFPATH=.;;
DFPROG=.;S:\;
DFREREADOPT=1
DFSTATION=m3c
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\
LOCALAPPDATA=C:\Users\ \AppData\Local
LOGONSERVER=\\
MV=F:\
NUMBER_OF_PROCESSORS=4
OS=Windows_NT
Path=;S:\.;F:\Publico;C:\ProgramData\Oracle\Java\javapath;..\ARCH\code\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;..\DLL
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_ARCHITEW6432=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 63 Stepping 2, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=3f02
ProgramData=C:\ProgramData
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\TEMP
TMP=C:\TEMP
USERDOMAIN=
USERNAME=
USERPROFILE=C:\Users\
USR=
windir=C:\Windows
windows_tracing_flags=3
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
Modules    =
00400000 SyncBackFree.exe                         8.4.5.0            C:\Program Files (x86)\2BrightSparks\SyncBackFree
507f0000 actxprxy.dll                             6.1.7601.17514     C:\Windows\SysWOW64
50f50000 ieproxy.dll                              11.0.9600.18838    C:\Program Files (x86)\Internet Explorer
517c0000 EhStorShell.dll                          6.1.7600.16385     C:\Windows\system32
5e800000 shdocvw.dll                              6.1.7601.23896     C:\Windows\System32
602e0000 jscript9.dll                             11.0.9600.18838    C:\Windows\SysWOW64
60740000 NetworkExplorer.dll                      6.1.7601.17514     C:\Windows\system32
60a80000 PortableDeviceApi.dll                    6.1.7601.17514     C:\Windows\system32
60bf0000 hhctrl.ocx                               6.1.7600.16385     C:\Windows\system32
60d50000 SearchFolder.dll                         6.1.7601.17514     C:\Windows\system32
60e00000 sppc.dll                                 6.1.7601.17514     C:\Windows\system32
60e30000 twext.dll                                6.1.7601.17514     C:\Windows\system32
60e60000 itss.dll                                 6.1.7600.16385     C:\Windows\System32
624f0000 api-ms-win-downlevel-advapi32-l2-1-0.dll 6.2.9200.16492     C:\Windows\system32
62500000 EhStorAPI.dll                            6.1.7601.17514     C:\Windows\system32
62530000 StructuredQuery.dll                      7.0.7601.23451     C:\Windows\System32
627e0000 cscobj.dll                               6.1.7601.17514     C:\Windows\System32
62850000 Slwga.dll                                6.1.7601.17514     C:\Windows\system32
62930000 ntshrui.dll                              6.1.7601.17755     C:\Windows\system32
62a20000 security.dll                             6.1.7600.16385     C:\Windows\system32
62a30000 thumbcache.dll                           6.1.7601.17514     C:\Windows\SysWOW64
63ed0000 mshtml.dll                               11.0.9600.18838    C:\Windows\SysWOW64
653b0000 nViewH.dll                               6.14.10.14892      C:\Program Files\NVIDIA Corporation\nview
65fe0000 WindowsCodecs.dll                        6.2.9200.21830     C:\Windows\system32
662a0000 explorerframe.dll                        6.1.7601.23893     C:\Windows\system32
66a00000 DUI70.dll                                6.1.7600.16385     C:\Windows\system32
67630000 slc.dll                                  6.1.7600.16385     C:\Windows\system32
67670000 XceedZip.dll                             6.5.14508.0        C:\Program Files (x86)\2BrightSparks\SyncBackFree
67920000 LINKINFO.dll                             6.1.7600.16385     C:\Windows\system32
690c0000 taskschd.dll                             6.1.7601.17514     C:\Windows\SysWOW64
6b8a0000 mscoreei.dll                             4.7.2117.0         C:\Windows\Microsoft.NET\Framework\v4.0.30319
6b950000 cscapi.dll                               6.1.7601.17514     C:\Windows\system32
6b9d0000 FaultRep.dll                             6.1.7601.17514     C:\Windows\system32
6bbd0000 D3D10Warp.dll                            6.2.9200.17033     C:\Windows\system32
6bdc0000 mscoree.dll                              4.0.40305.0        C:\Windows\system32
6be40000 DWrite.dll                               6.2.9200.22164     C:\Windows\system32
6bf80000 d2d1.dll                                 6.2.9200.16765     C:\Windows\system32
6c4e0000 ieframe.DLL                              11.0.9600.18838    C:\Windows\system32
6e020000 DUser.dll                                6.1.7600.16385     C:\Windows\system32
6e420000 wsock32.dll                              6.1.7600.16385     C:\Windows\system32
6e440000 mpr.dll                                  6.1.7600.16385     C:\Windows\system32
6e6b0000 gdiplus.dll                              6.1.7601.23894     C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23894_none_5c0be957a009922e
6ea40000 XmlLite.dll                              1.3.1001.0         C:\Windows\system32
6f3a0000 olepro32.dll                             6.1.7601.23452     C:\Windows\system32
6f640000 msls31.dll                               3.10.349.0         C:\Windows\system32
6f680000 msimtf.dll                               6.1.7600.16385     C:\Windows\system32
6f8e0000 schannel.dll                             6.1.7601.23915     C:\Windows\SysWOW64
6f930000 credssp.dll                              6.1.7601.23915     C:\Windows\system32
705b0000 winspool.drv                             6.1.7601.17514     C:\Windows\system32
70710000 wship6.dll                               6.1.7600.16385     C:\Windows\System32
70ac0000 api-ms-win-downlevel-shlwapi-l2-1-0.dll  6.2.9200.16492     C:\Windows\system32
70ad0000 GPAPI.dll                                6.1.7601.23452     C:\Windows\system32
70af0000 bcryptprimitives.dll                     6.1.7601.23451     C:\Windows\SysWOW64
70b40000 ncrypt.dll                               6.1.7601.23915     C:\Windows\system32
70c50000 propsys.dll                              7.0.7601.17514     C:\Windows\system32
70d50000 COMCTL32.dll                             6.10.7601.18837    C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d
70ef0000 api-ms-win-downlevel-shell32-l1-1-0.dll  6.2.9200.16492     C:\Windows\system32
70f00000 oleacc.dll                               7.0.0.0            C:\Windows\system32
71140000 fwpuclnt.dll                             6.1.7601.18283     C:\Windows\System32
711c0000 rasadhlp.dll                             6.1.7600.16385     C:\Windows\system32
711f0000 SECUR32.DLL                              6.1.7601.23915     C:\Windows\system32
71200000 webio.dll                                6.1.7601.23375     C:\Windows\system32
71250000 winhttp.dll                              6.1.7601.23451     C:\Windows\system32
71e90000 apphelp.dll                              6.1.7601.19050     C:\Windows\system32
727d0000 MLANG.dll                                6.1.7600.16385     C:\Windows\system32
72930000 dhcpcsvc.DLL                             6.1.7600.16385     C:\Windows\system32
72950000 DNSAPI.dll                               6.1.7601.17570     C:\Windows\system32
729a0000 wshtcpip.dll                             6.1.7600.16385     C:\Windows\System32
729b0000 mswsock.dll                              6.1.7601.23451     C:\Windows\system32
729f0000 swi_ifslsp.dll                           3.6.0.2087         C:\ProgramData\Sophos\Web Intelligence
72e90000 dhcpcsvc6.DLL                            6.1.7601.17970     C:\Windows\system32
72ef0000 winmm.dll                                6.1.7601.17514     C:\Windows\system32
732e0000 bcrypt.dll                               6.1.7601.23915     C:\Windows\System32
73300000 msxml6.dll                               6.30.7601.18980    C:\Windows\System32
73460000 WINNSI.DLL                               6.1.7601.23889     C:\Windows\system32
73470000 iphlpapi.dll                             6.1.7601.17514     C:\Windows\system32
73640000 version.dll                              6.1.7600.16385     C:\Windows\system32
73700000 wkscli.dll                               6.1.7601.17514     C:\Windows\system32
73710000 srvcli.dll                               6.1.7601.17514     C:\Windows\system32
73730000 netutils.dll                             6.1.7601.17514     C:\Windows\system32
73740000 netapi32.dll                             6.1.7601.17887     C:\Windows\system32
73d70000 DAVHLPR.dll                              6.1.7600.16385     C:\Windows\System32
73de0000 davclnt.dll                              6.1.7601.23542     C:\Windows\System32
73e00000 ntlanman.dll                             6.1.7601.17514     C:\Windows\System32
73e20000 drprov.dll                               6.1.7600.16385     C:\Windows\System32
73ec0000 SXS.DLL                                  6.1.7601.17514     C:\Windows\system32
73f20000 RpcRtRemote.dll                          6.1.7601.17514     C:\Windows\system32
73f30000 rsaenh.dll                               6.1.7600.16385     C:\Windows\system32
73f70000 CRYPTSP.dll                              6.1.7601.23471     C:\Windows\system32
73fb0000 ntmarta.dll                              6.1.7600.16385     C:\Windows\system32
73fe0000 WINSTA.dll                               6.1.7601.18540     C:\Windows\system32
74010000 wtsapi32.dll                             6.1.7601.17514     C:\Windows\system32
74110000 d3d11.dll                                6.2.9200.16570     C:\Windows\system32
742c0000 dwmapi.dll                               6.1.7601.18917     C:\Windows\system32
742e0000 dxgi.dll                                 6.2.9200.16492     C:\Windows\system32
74330000 uxtheme.dll                              6.1.7600.16385     C:\Windows\system32
743b0000 sophos_detoured.dll                      10.7.2.49          C:\Program Files (x86)\Sophos\Sophos Anti-Virus
747c0000 CRYPTBASE.dll                            6.1.7601.23915     C:\Windows\syswow64
747d0000 SspiCli.dll                              6.1.7601.23915     C:\Windows\syswow64
74830000 WININET.dll                              11.0.9600.18838    C:\Windows\syswow64
74ae0000 shlwapi.dll                              6.1.7601.17514     C:\Windows\syswow64
74b40000 USERENV.dll                              6.1.7601.17514     C:\Windows\syswow64
74b60000 CLBCatQ.DLL                              2001.12.8530.16385 C:\Windows\syswow64
74bf0000 RPCRT4.dll                               6.1.7601.23915     C:\Windows\syswow64
74ce0000 MSASN1.dll                               6.1.7601.17514     C:\Windows\syswow64
74cf0000 api-ms-win-downlevel-version-l1-1-0.dll  6.2.9200.16492     C:\Windows\syswow64
74d00000 msvcrt.dll                               7.0.7601.17744     C:\Windows\syswow64
74db0000 api-ms-win-downlevel-ole32-l1-1-0.dll    6.2.9200.16492     C:\Windows\syswow64
74dc0000 NSI.dll                                  6.1.7601.23889     C:\Windows\syswow64
74e00000 CFGMGR32.dll                             6.1.7601.17621     C:\Windows\syswow64
74e30000 api-ms-win-downlevel-normaliz-l1-1-0.dll 6.2.9200.16492     C:\Windows\syswow64
74e40000 crypt32.dll                              6.1.7601.23769     C:\Windows\syswow64
74f70000 WS2_32.dll                               6.1.7601.23451     C:\Windows\syswow64
74fb0000 api-ms-win-downlevel-shlwapi-l1-1-0.dll  6.2.9200.16492     C:\Windows\syswow64
74fc0000 WINTRUST.dll                             6.1.7601.23769     C:\Windows\syswow64
74ff0000 MSCTF.dll                                6.1.7601.23915     C:\Windows\syswow64
750c0000 IMM32.DLL                                6.1.7601.17514     C:\Windows\system32
75120000 normaliz.DLL                             6.1.7600.16385     C:\Windows\syswow64
75130000 iertutil.dll                             11.0.9600.18838    C:\Windows\syswow64
75400000 ADVAPI32.dll                             6.1.7601.23915     C:\Windows\syswow64
754b0000 api-ms-win-downlevel-advapi32-l1-1-0.dll 6.2.9200.16492     C:\Windows\syswow64
754c0000 ole32.dll                                6.1.7601.23889     C:\Windows\syswow64
75620000 api-ms-win-downlevel-user32-l1-1-0.dll   6.2.9200.16492     C:\Windows\syswow64
75690000 Setupapi.dll                             6.1.7601.17514     C:\Windows\syswow64
75830000 SHELL32.dll                              6.1.7601.23893     C:\Windows\syswow64
76480000 KERNELBASE.dll                           6.1.7601.23915     C:\Windows\syswow64
764d0000 profapi.dll                              6.1.7600.16385     C:\Windows\syswow64
764e0000 sechost.dll                              6.1.7601.18869     C:\Windows\SysWOW64
76500000 PSAPI.DLL                                6.1.7600.16385     C:\Windows\syswow64
76510000 urlmon.dll                               11.0.9600.18838    C:\Windows\syswow64
76660000 WLDAP32.dll                              6.1.7601.23889     C:\Windows\syswow64
766b0000 USP10.dll                                1.626.7601.23894   C:\Windows\syswow64
76750000 DEVOBJ.dll                               6.1.7601.17621     C:\Windows\syswow64
76770000 GDI32.dll                                6.1.7601.23914     C:\Windows\syswow64
76800000 comdlg32.dll                             6.1.7601.17514     C:\Windows\syswow64
76880000 USER32.dll                               6.1.7601.23594     C:\Windows\syswow64
76980000 OLEAUT32.dll                             6.1.7601.23775     C:\Windows\syswow64
76a20000 kernel32.dll                             6.1.7601.23915     C:\Windows\syswow64
76f00000 LPK.dll                                  6.1.7601.23930     C:\Windows\syswow64
76f30000 ntdll.dll                                6.1.7601.23915     C:\Windows\SysWOW64
10:05:36=ProfileEngine.TRunProfile.Create.1252:Unattended: 0 [0]
10:05:36=ProfileEngine.TRunProfile.Create.1324:Start [0]
10:05:36=ProfileEngine.TRunProfile.Create.1325:Priority [3]
10:05:36=ProfileEngine.TRunProfile.Create.1326:Trigger [Manual]
10:05:36=ProfileEngine.TRunProfile.Create.1337:Group:
10:05:36=FileListBase.TFileList.CreateList.1032
10:05:36=FileListBase.TFileList.CloseSort.1433
10:05:36=ProfileEngine.TRunProfile.GetFastBackupSettings.1756:FASTBACKUP [0]
10:05:36=ProfileEngine.TRunProfile.Create.1474:AvgFiles [0]
10:05:36=ProfileEngine.TRunProfile.Create.1475:AvgDirs [0]
10:05:36=ProfileEngine.TRunProfile.Create.1599:VERIFY [2]
10:05:36=ProfileEngine.TRunProfile.Create.1636:Attended
10:05:36=SBListStrings.TSBListStrings.SortFIFOEx.506
10:05:36=ProfileEngine.TRunProfile.Create.1696:Finished
10:05:36=ProfileEngine.TRunProfile.Execute.3217:03 mCosmos partial past week
10:05:36=ProfileEngine.TRunProfile.SaveProfileResult.13315 [4]
10:05:36=ProfileEngine.TRunProfile.SaveProfileResult.13357:Saving... [4]
10:05:36=ProfileEngine.TRunProfile.ConfigureThread.5310
10:05:36=ProfileEngine.TRunProfile.ConfigureThread.5334:Stopping Windows from sleeping
10:05:36=ProfileEngine.TRunProfile.CreateZip.4084:IsCompressed
10:05:36=ZipXceed.TXceedWrapper.SetZipTempDir.996
10:05:36=ZipXceed.TXceedWrapper.SetZipTempDir.1019
10:05:36=ZipXceed.TXceedWrapper.SetCompressionMethod.816:1
10:05:36=ProfileEngine.TRunProfile.CreateZip.4131:Method [1]
10:05:36=ZipXceed.TXceedWrapper.SetCompressionLevel.805:0
10:05:36=Zip64Wrapper.TZip64Wrapper.SetZipFilter.486:.7z,.ace,.alz,.apk,.arc,.arj,.avi,.b1,.bh,.bwt,.bz2,.cab,.cdx,.cfs,.dar,.dmg,.gho,.gif,.gz,.gzip,.ice,.j,.jar,.jpeg,.jpg,.kgb,.lha,.lzh,.lzma,.mov,.mp1,.mp2,.mp3,.mpeg,.mpg,.pak,.partimg,.pea,.png,.qda,.rar,.sfx,.sitx,.sqx,.swf,.tbz2,.tgz,.tib,.tif,.tiff,.tlz,.wim,.wmv,.wvl,.xar,.z,.zip,.zipx,.zoo,.zpaq,.zz
10:05:36=ProfileEngine.TRunProfile.CreateZip.4136:Level [0]
10:05:36=ProfileEngine.TRunProfile.CreateZip.4177:SingleZip
10:05:36=ZipXceed.TXceedWrapper.SetIsMultiZip.986:0
10:05:36=ZipXceed.TXceedWrapper.SetSplitSizeKB.1819:0
10:05:36=ZipXceed.TXceedWrapper.SetBaseDir.787:\\?\UNC\ \ \cmm\!backups\!mcosmos program folder daily partial backup\
10:05:36=ProfileEngine.TRunProfile.CreateSourceLocation.4985:Safe copies: Yes
10:05:36=LocationsBase.TBaseLocation.Create.822
10:05:36=LocationsBase.TBaseLocation.SetRealBaseDir.1179:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup]
10:05:36=LocationsNormal.TNormalLocation.Create.902
10:05:36=LocationsBase.TBaseLocation.SetDesktopINI.3036:0
10:05:36=ProfileEngine.TRunProfile.CreateSourceLocation.5175:Source [Source]
10:05:36=ProfileEngine.TRunProfile.CreateDestLocation.4779:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:36=LocationsBase.TBaseLocation.SetRealBaseDir.1179:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip]
10:05:36=LocationsSingleZip.TSingleZipLocation.Create.1009
10:05:36=ProfileEngine.TRunProfile.CreateDestLocation.4977:Destination [Destination]
10:05:36=ProfileEngine.TRunProfile.ReconfigSettings.4548
10:05:36=ProfileEngine.TRunProfile.RunTheProfile.5629
10:05:36=ProfileEngine.TRunProfile.DoLoadMedia.6157:Source
10:05:36=ProfileEngine.TRunProfile.DoLoadMedia.6157:Destination
10:05:36=ProfileEngine.TRunProfile.DoPause.6242:10
10:05:46=ProfileEngine.TRunProfile.DoRunBefore.6342
10:05:46=FileListBase.TFileList.CloseSort.1433
10:05:46=SBListStrings.TSBListStrings.SortFIFOEx.506
10:05:46=ProfileEngine.TRunProfile.DoRunBefore.6364:Nothing to run
10:05:46=ProfileEngine.TRunProfile.DoCreateVSS.6274
10:05:46=ProfileEngine.TRunProfile.DoNetworkConnect.6456:NetworkConnect
10:05:46=ProfileEngine.TRunProfile.NetworkConnect.12877
10:05:46=NetDrive.TNetDrive.NetConnect.116:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup [-1]
10:05:46=NetDrive.TNetDrive.FConnect.206:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup
10:05:46=[W]:NetDrive.TNetDrive.FConnect.220:Not already connected [This network connection does not exist]
10:05:46=NetDrive.TNetDrive.FConnect.229:Can access files [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup]
10:05:46=NetDrive.TNetDrive.FConnect.240:Already connected, will not disconnect
10:05:46=NetDrive.TNetDrive.NetConnect.116:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip [-1]
10:05:46=NetDrive.TNetDrive.FConnect.206:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=NetDrive.TNetDrive.FConnect.229:Can access files [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip]
10:05:46=ProfileEngine.TRunProfile.DoPrepLocation.2035:Source [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup]
10:05:46={2033027/64060 01.63% 00.08% 271/298}
10:05:46=LocationsBase.TBaseLocation.SetRealBaseDir.1179:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup]
10:05:46=ProfileEngine.TRunProfile.DoPrepLocation.2086:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup
10:05:46=ProfileEngine.TRunProfile.DoPrepLocation.2035:Destination [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip]
10:05:46=LocationsBase.TBaseLocation.SetRealBaseDir.1179:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip]
10:05:46=ProfileEngine.TRunProfile.DoPrepLocation.2086:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=LocationsNormal.TNormalLocation.RefreshVolumeInformation.1558
10:05:46=[E]:WindowsFS.TWindowsFS.WhereJunciontPoint.552:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup: The file or directory is not a reparse point (4390) [DeviceIoControl: The file or directory is not a reparse point]
10:05:46=LocationsSingleZip.TSingleZipLocation.RefreshVolumeInformation.1291
10:05:46=[E]:WindowsFS.TWindowsFS.WhereJunciontPoint.552:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip: The file or directory is not a reparse point (4390) [DeviceIoControl: The file or directory is not a reparse point]
10:05:46=ProfileEngine.TRunProfile.DoPrepBaseDir.2328:Source [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup]
10:05:46=ProfileEngine.TRunProfile.DoPrepBaseDir.2328:Destination [\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip]
10:05:46=SingleZipHelper.TSingleZipHelper.OpenLocalSingleZip.216:Destination
10:05:46=Zip64Wrapper.TZip64Wrapper.OpenZipFile.456:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=ZipXceed.TXceedWrapper.SetZipFilename.879:\\?\UNC\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=SingleZipHelper.TSingleZipHelper.OpenRemoteSingleZip.568:Destination
10:05:46=FileListBase.TFileList.CreateList.1032
10:05:46=ProfileEngine.TRunProfile.DoPrepareLog.7926
10:05:46=Log.TLog.OpenLogFile.471
10:05:46=BuildLog.TBuildLog.Create.77
10:05:46=BuildLog.TBuildLog.Create.86:Temp filename [C:\TEMP\~SB1631.tmp]
10:05:46=ProfileEngine.TRunProfile.LogLocationInfo.7611:-1
10:05:46=Log.TLog.LocationInfo.1067
10:05:46=ProfileEngine.TRunProfile.LogLocationInfo.7611:0
10:05:46=ProfileEngine.TRunProfile.ScanSourceDest.6731
10:05:46=ProfileEngine.TRunProfile.MustScanDestination.3814:-1
10:05:46=ProfileEngine.TRunProfile.Scan.7229:Source [SCAN BEGIN]
10:05:46=ProfileEngine.TRunProfile.CreateScanner.6959:Source
10:05:46={2032455/64632 01.63% 00.08% 271/297}
10:05:46=TreeScanBase.TBaseTreeScanner.Create.318
10:05:46=TreeScanBase.TBaseTreeScanner.SetFileList.396
10:05:46=TreeScanBase.TBaseTreeScanner.SetCompDirList.408
10:05:46=TreeScanBase.TBaseTreeScanner.SetErrDirectories.420
10:05:46=ProfileEngine.TRunProfile.CreateScanner.7218:Versioning [0]
10:05:46=TreeScanNormal.TNormalTreeScanner.ScanTree.223:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup
10:05:46=TreeScanNormal.TNormalTreeScanner.IntScanDirectory.322:\\ \ \cmm\!backups\!mcosmos program folder daily partial backup\ [-1]
10:05:46=TreeScanBase.TBaseTreeScanner.AddMatchedDirToList.680:\
10:05:46=TreeScanBase.TBaseTreeScanner.AddToFileList.882:\1monday mcosmos folder partial backup.zip
10:05:46=TreeScanBase.TBaseTreeScanner.AddToFileList.882:\4thursday mcosmos folder partial backup.zip
10:05:46=TreeScanBase.TBaseTreeScanner.AddToFileList.882:\5friday mcosmos folder partial backup.zip
10:05:46=TreeScanBase.TBaseTreeScanner.AddToFileList.882:\3wednesday mcosmos folder partial backup.zip
10:05:46=TreeScanBase.TBaseTreeScanner.AddToFileList.882:\2tuesday mcosmos folder partial backup.zip
10:05:46=ProfileEngine.TRunProfile.Scan.7267:Source [SCAN END, 0 secs]
10:05:46=ProfileEngine.TRunProfile.Scan.7268:Source [5 files, 1 folders]
10:05:46=ProfileEngine.TRunProfile.Scan.7229:Destination [SCAN BEGIN]
10:05:46=ProfileEngine.TRunProfile.CreateScanner.6959:Destination
10:05:46=TreeScanSingleZip.TSingleZipTreeScanner.ScanTree.251:\\?\UNC\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=Zip64Wrapper.TZip64Wrapper.SetOnListingFile.476
10:05:46=Zip64Wrapper.TZip64Wrapper.ClearList.528
10:05:46=Zip64Wrapper.TZip64Wrapper.OpenZipFile.456:\\?\UNC\ \ \cmm\!backups\!mcosmos program folder daily partial backup\past week\past week backup.zip
10:05:46=ZipXceed.TXceedWrapper.PopulateList.1370:-1
10:05:46=[E]:ProfileEngine.TRunProfile.InsertDiskMissing.14007:The last part of the Zip file is missing
10:05:46=[E]:ZipXceed.TXceedWrapper.PopulateList.1407:The user aborted the request to insert a new disk (or no InsertDisk event was implemented). (517)
10:05:46=ProfileEngine.TRunProfile.Scan.7267:Destination [SCAN END, 0 secs]
10:05:46=ProfileEngine.TRunProfile.Scan.7268:Destination [5 files, 1 folders]
10:05:46=[E]:ProfileEngine.TRunProfile.ShowDialog.13678:Failed to scan files: The user aborted the request to insert a new disk (or no InsertDisk event was implemented). (517) (Destination) [Failed to scan files: %s]
10:05:46=ProfileEngine.TRunProfile.GetModalCS.13573
10:05:46=ProfileEngine.TRunProfile.GetModalCS.13579:First attempt
10:05:46=ProfileEngine.TRunProfile.GetModalCS.13597:Done
10:05:46=ProfileEngineUI.TShowEngineUIBase.WaitForTermination.228:Waiting
10:05:54=ProfileEngineUI.TShowEngineUIBase.WaitForTermination.238:Finished waiting [1]
10:05:54=ProfileEngine.TRunProfile.RunTheProfile.6081:Result [6]
10:05:54=ProfileEngine.TRunProfile.PostCopy.10825:6
10:05:54=ProfileEngine.TRunProfile.DoRunAfter.10743
10:05:54=[W]:ProfileEngine.TRunProfile.DoRunAfter.10810:Not run
10:05:54=Log.TLog.PostRunInfo.965
10:05:54=Log.TLog.Aborted.1186:Simulation Aborted
10:05:54=Log.TLog.CloseLogFile.579:1
10:05:54=Log.TLog.ConvertLogFile.1438:1
10:05:54=BuildLog.TBuildLog.Destroy.94
10:05:54=ProfileEngine.TRunProfile.DoEjectMedia.6203:Source
10:05:54=ProfileEngine.TRunProfile.DoEjectMedia.6203:Destination
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2759
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2763:FSourceLoc
10:05:54=LocationsBase.TBaseLocation.Destroy.959:FHasher
10:05:54=LocationsBase.TBaseLocation.Destroy.962:FVerFilter
10:05:54=LocationsBase.TBaseLocation.Destroy.965:FVerifyFilter
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2765:FDestLoc
10:05:54=LocationsSingleZip.TSingleZipLocation.Destroy.1045
10:05:54={2032251/64836 01.25% 00.45% 279/297}
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2767:FSourceVer
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2769:FDestVer
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2771:FCompFileList
10:05:54=FileListBase.TFileList.CloseSort.1433
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2773:FSmartSyncFileList
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2775:FCompDirList
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2777:FSmartSyncDirList
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2779:FAverages
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2781:FZipHelper
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2783:FDiskCatalog
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2785:FJPList
10:05:54=ProfileEngine.TRunProfile.FreeMemory.2840:Done
10:05:54=ProfileEngine.TRunProfile.SyncShowLog.13607
10:05:55=ProfileEngine.TRunProfile.NetworkDisconnect.12941
10:05:55=ProfileEngine.TRunProfile.SaveProfileResult.13315 [6]
10:05:55=ProfileEngine.TRunProfile.SaveProfileResult.13357:Saving... [6]
10:05:55=ProfileEngine.TRunProfile.HandleTerminate.3023:6 [0]
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2759
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2763:FSourceLoc
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2765:FDestLoc
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2767:FSourceVer
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2769:FDestVer
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2771:FCompFileList
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2773:FSmartSyncFileList
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2775:FCompDirList
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2777:FSmartSyncDirList
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2779:FAverages
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2781:FZipHelper
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2783:FDiskCatalog
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2785:FJPList
10:05:55=ProfileEngine.TRunProfile.FreeMemory.2840:Done
10:05:55=[E]:ProfileEngine.TRunProfile.HandleTerminate.3087:Critical Error [Failed to scan files: The user aborted the request to insert a new disk (or no InsertDisk event was implemented). (517) (Destination)]
10:05:55=FileListBase.TFileList.CloseSort.1433
10:05:55=---:LOG FILE CLOSED [28-Nov-17 10:05:55 AM]
Blaeul
Postby Blaeul » Wed Nov 29, 2017 6:25 pm
We didn’t find a solution.
Return to “SyncBackFree (freeware)”
