New beta versions uploaded
Postby mickyj » Fri Feb 24, 2012 8:58 am
New versions of the service (V1.4) and console (V2.1) have been uploaded:
New: Access can be controlled using hostname as well as IP address
New: Console can now set connection settings of a local service without being logged in and also restart it
Updated: Service will repeatedly try to start instead of only trying once, e.g. to fix issues where the port is being used
Re: New beta versions uploaded
Postby mickyj » Sat Feb 25, 2012 2:46 am
There was a mistake in the installation for this beta version.
On 64-bit versions of Windows it incorrectly installed to the 64-bit program files folder. We've uploaded new beta versions to fix this.
After installing the new beta versions (V1.4.1 and V2.1.1) you can delete the previous version manually from the following folders:
C:\Program Files\2BrightSparks\SBMService\
C:\Program Files\2BrightSparks\SBMConsole\
If you are using 32-bit Windows then there is no need to do this.
