Login Failed: Connection exception: No connection available.
pawel
Post by pawel » Wed Jul 08, 2015 3:35 pm
I just bought and installed SBM service. Machine is Windows 2012 R2. No firewall installed.
Connecting via console locally works. Connecting from any other machine fails with error.
I tried different ports, passwords, profiles, etc.
Re: Login Failed: Connection exception: No connection available.
Post by mickyj » Thu Jul 09, 2015 2:06 am
Hi, have you configured SBMS to allow connections from other computers? Run the Console and go to Service->IP Addresses from the main menu. By default, for security reasons, you can only login from the same computer the service is installed on. You need to change this as appropriate. You can also allow connections based on the hostname (see Service->Hostnames).
pawel
Post by pawel » Fri Jul 10, 2015 2:36 pm
I should be more specific: connection via SBM console works. I am able to use any machine and connect to server.
I have a problem with SyncBack 6.2.11.0 management service connection. I can not connect.
pawel
Post by pawel » Fri Jul 10, 2015 3:41 pm
Upgrade to 6.5.49.0 fix the problem.
Post by cliffhanger » Fri Jul 10, 2015 8:44 pm
Presumably because of points 4 & 5 here
http://www.2brightsparks.com/bb/viewtop ... =27&t=9864
and the fact that as a new SBMS user you never had SBM Service V1 installed (which is all Pro 6.2.x worked with)
