SynckBack and USB Key
naeco
Post by naeco » Thu Jun 16, 2016 9:24 am
I would like to submit an idee :)
It will be interessant to have a possibility in Syncback to synchronize a repository with a repository on a USB Key, and to lauch this automaticaly when we plug the USB Key.
Thank for your soft, pretty useful :)
best regards
Re: SynckBack and USB Key
Post by cliffhanger » Thu Jun 16, 2016 11:24 am
Hi, the commercial versions (Pro & SE) have been able to do this for years - see
Modify -> Expert -> When -> Insert
Not sure which version you're using, as you didn't say (or post in a version-specific forum section), but the freeware version doesn't support this, so you may need to upgrade. If so, other benefits of upgrading are here (click the link at the bottom of that page to expand / see all)
naeco
Post by naeco » Thu Jun 16, 2016 12:35 pm
OK ! Thank's for your answer !
