suggestion: Portable version?
Postby HaseAbtwil » Tue Mar 08, 2016 7:52 am
I am using SyncBackSE for years and I like it still very much. But now my workplace environment gets changed wherein I cannot install anything anymore on my own. Therefore I am looking for "SyncBackSE_portable", means I am looking for a way to install/configure (+ license :) my Syncback on the physical machine but run the syncback process itself in the citrix/TS app from a command prompt with a specific profile mentioned. My problem: from the citrix/TS desktop I can access my physical disks, but not the other direction.
Has anybody an idea? I have looked for other tools but none of them was nearby as good as SyncBack ...
Any hint would be appreciated very much!
Re: suggestion: Portable version?
Postby Kostas » Tue Mar 08, 2016 8:43 am
You haven't mentioned which version of SyncBackSE you are using.
You can get the non-install versions from the following links:
SyncBackSE V7: ...
SyncBackSE V6: ...
SyncBackSE V5: ...
Return to “Ideas and general discussion”
