Menu bar of is broken in Chrome
Postby AndreyT » Wed Feb 18, 2015 8:02 pm
Are you aware of the fact that the menu bar of your web site does not work properly in Chrome if the current Zoom level is different from 100%?
I'm referring to the drop down menu bar featured on web pages. The one that says "Home - Products - Downloads - Buy ..." and so on. When the user hovers over the bar with the mouse, a drop down menu is supposed to appear under the corresponding bar entry. When Zoom level in Chrome is set to a value greater that 100%, the drop down menu will appear "detached" from the bar entry and displaced down and to the right. The greater the current zoom level, the farther is the displacement. It is impossible to use the drop down menu in this mode. If the current Zoom level is below 100%, the drop down is displaced up and to the left.
Re: Menu bar of is broken in Chrome
Postby mike » Thu Feb 19, 2015 6:58 am
Hi, thanks for reporting this problem. I am sorry that the issue in Chrome prevents the site from being easily navigated when increasing or decreasing the zoom level. We're currently working on a site redesign, and the new menu will hopefully resolve this problem. In the meantime, I suggest you use the site map for navigation and open pages in a new tab:
Kind Regards,
Mike de Sousa
2BrightSparks Pte Ltd
Power with Ease - Indispensable Utility Software
Return to “Ideas and general discussion”
