REQUEST: network Sync App?
gigomikol
Postby gigomikol » Thu Jul 24, 2014 1:24 pm
Hello
(first post) I read through the FAQ and did a good search before posting so i hope i am doing this correctly.
My "idea" or request would be for possibly an Android or IOS app that can control the synchronizing/backup of data between 2 network attached storage drives.
Scenario:
I have 2 NAS drives connected to my home network
the first NAS is the DAILY backup from my PC
the second NAS is the MONTHLY backup from the primary NAS
In order to run the backup from NAS to NAS i have to let my computer run syncbackpro all night long. Is there a simpler way to use the current software or a better way to run a backup from NAS to NAS with maybe an ios or android device app on the same network?
If it helps i can also connect the secondary NAS drive via USB to the Primary Nas drive.
Please let me know if this is feasible and if i can help in anyway with testing, thank you for a great product and your time!
Rainz
Re: REQUEST: network Sync App?
Postby Rainz » Thu Aug 07, 2014 9:25 am
How are you using SyncBackPro? Some NAS models have support for their own Apps, like my AsusStor or Synology, but that does not involve SyncBackPro so I do not see how you will get any help on Apps here?
Rainz
Postby Rainz » Thu Aug 07, 2014 9:30 am
can bot edit my post it seems..
Anyhow, the performance on copying one NAS to another depends on network speed amount of files and filesize. That can vary a lot, even when optimized, I have reached speeds above 100MB/S for single large files.
Copying once a month seems a bit low frequency to me, I run daily jobs on 2,76 TB files and increasing. Mirror.
gigomikol
Postby gigomikol » Thu Aug 07, 2014 11:03 am
Rainz wrote:can bot edit my post it seems..
I currently have a slink nas 323 and a western digital my backup nas,
The job that I have that runs DAILY is to my DLINK 323 with 2 mirrored drives ,
The backup job I have that runs monthly is to copy from the 323 to my WD drive.
My home network is pretty fast as I have an r7000 netgear nighthawk wireless router connected to the 2 drives.
I was just looking for a solution to do a backup from IP address to IP address without using the computer all night,
Return to “Ideas and general discussion”
