OnClick and Windows 10
Postby mickyj » Thu Aug 20, 2015 3:54 am
We've released new versions of all the OnClick utilities and an updated help file. All the OnClick utilities now support Windows 10.
The new version of FindOnClick also includes the following changes:
New: Ctrl-F5 will do a quick refresh (it will remove files and folders from the results that no longer exist and only recalc hash values of changed files)
New: Add path manually via pop-up menu or ctrl-click the Add Path link
Updated: If the Only show duplicate files option is enabled then it will be quicker as it will not hash obviously unique files
Fixed: DOS filename shown if Windows standard search used
Return to “OnClick Utilities”
