DeleteOnClick - command line
Zeuzero
Post by Zeuzero » Mon Aug 18, 2014 7:34 pm
Hi, I've bought the Commercial Version.
With Freeware version I had, DoC folder had only dll files, or something like that.
While now there is also a
DOCERB.exe
file.
Command line, changed directory to DoC, launched
C:\Programs\2BrightSparks\DeleteOnClick\DOCERB.exe /?
I see DeleteOnClick starting, executing something whith a flashing popup and the disappearing.
However, the folder has still all the files, so (I hope) nothing happened (in any case I've my backup).
So, is there any way to use DoC by command line?
Any hint? Cheers. Z
Re: DeleteOnClick - command line
Post by mickyj » Mon Aug 18, 2014 11:02 pm
Hi, DOCERB is used to securely empty the recycle bin. There is no command line version to securely wipe specific files.
Zeuzero
Post by Zeuzero » Wed Aug 20, 2014 8:07 am
Ok, a bit more relieved.
Thanks.
Cheers. A.
