FindOnClick V2.6.0.0 BETA
Post by mickyj » Tue Apr 15, 2014 9:24 am
A beta version of FindOnClick V2.6.0.0 is available for download:
It includes the following changes:
New: Ctrl-F5 will do a quick refresh (it will remove files and folders from the results that no longer exist and only recalc hash values of changed files)
New: Add path manually via pop-up menu or cltr-click the Add Path link
Updated: If the Only show duplicate files option is enabled then it will be quicker as it will not hash obviously unique files
Fixed: DOS filename shown if Windows standard search used
