New OnClick versions (February 2014)
Post by mickyj » Thu Feb 13, 2014 8:44 am
New versions of the OnClick utilites are now available for download:
DeleteOnClick V2.3.0.0
http://www.2brightsparks.com/assets/software/DeleteOnClick_Setup.exe
New: Extra confirmation if wiping everything on a drive
Updated: Installer wont ask to close Windows Explorer
FindOnClick V2.5.0.0
http://www.2brightsparks.com/assets/software/FindOnClick_Setup.exe
New: Deep file search option (to search using ASCII, Unicode (LE, BE, and UTF-8))
New: -deep command line parameter
Fixed: Bug where Filename filter was interpreted incorrectly with 3 or more items
EncryptOnClick V1.5.0.0
http://www.2brightsparks.com/assets/software/EncryptOnClick_Setup.exe
New: Option to show password
New: Option to not delete file after encrypting or decrypting
New: -n command line parameter to specify not to delete file
HashOnClick V2.5.1.0
http://www.2brightsparks.com/assets/software/HashOnClick_Setup.exe
