When trying to backup files (for the first time) to a NAS, most of the files copied without incident(26K files), except for a bunch which did not (24K files had this error) with the following error message:
"Failed to copy from Source : Cannot create folder: \\192.168.1.19\FileBackup\Multimedia\Images\Family\Vacations\JenWedding2017\ (The specified path is invalid)"
Any ideas? It can't be because of the number of directories, as other files with more directories copied fine. Space is not an issue either, have 340GB available yet (after the attempted backup), while the source drive has only 285GB on it, and I'm not even backing up everything.
Windows 10 Pro 64-bit, build 1803
SyncBackSE V8.5.122.0 (64bit)
QNAP TS-259Pro+ with EXT4 file system.
