how do I install 64 bit version of SyncBackSE v8
folky
Postby folky » Tue Oct 24, 2017 6:25 pm
I paid the upgrade fee from v7 to v8. During the install of v8 I was expecting to see something about installing 32-bit vs 64-bit, but I didn't notice anything. When the install/upgrade finished, help\about says I have the 32-bit version of SyncBackSE v8. How do I install the 64-bit version of SyncBackSE v8?
Mark
folky
Re: how do I install 64 bit version of SyncBackSE v8
Postby folky » Tue Oct 24, 2017 10:26 pm
Somehow, after searching all over the website, I found a page which has the 32-bit and 64-bit versions. I downloaded the 64-bit. As the instructions say to do, I exported my 32-bit profiles, closed SyncBackSE, and started to uninstall 32-bit. It's been stuck at "Uninstalling SyncBackSE.." with the progress bar completely empty. But finally - after I started writing this message - after about 25 minutes, it did uninstall my 32-bit version. I then installed the 64-bit version and imported my 3 profiles. I'll assume it will work fine from there.
Mark
Return to “SyncBackSE (commercial)”
