Setting up automatic VPN connection
henwin
Post by henwin » Mon Sep 04, 2017 5:34 pm
Part of my backup routine requires 2 profiles to be run consecutively over a VPN connection to an off-site computer.
Is there some way I can set up SyncBack SE to connect automatically to the other computer through the VPN (which I have a connection for in Win10) or via the address to the other computer? Or should I enable and disable the VPN connection using Task Manager (and if yes, please provide some guidance on doing that).
I'm an experienced Windows user, but my networking knowledge isn't that great since I'm a standalone user at home.
thanks,
Henwin
Re: Setting up automatic VPN connection
Post by Swapna » Tue Sep 05, 2017 1:29 am
Please refer to this forum post for more details:
viewtopic.php?t=12496&p=47745#p47745
