Moving Folders Around and Deleting Files
pintosal
Post by pintosal » Tue Jul 11, 2017 2:38 pm
I have a server and a desktop, and I would like to have identical files and folders on both.
Initially, there are files on the server. When I start, I can set up synchronisation between desktop and the server, and the desktop will mirror the server.
Thereafter, I would like Synchback to do the following:
1. When I delete a file and/or a folder on the desktop, the corresponding file/folder should be deleted on the server.
2. When I move a folder on the desktop, this move should be reflected on the server.
3. When I delete a file and/or a folder on the server, the corresponding file/folder should be deleted on the desktop.
4. When I move some files or folders on the server, the corresponding file/folder should be moved on the desktop.
Is it possible to configure Synchback to achieve this?
Re: Moving Folders Around and Deleting Files
Post by Swapna » Wed Jul 12, 2017 9:03 am
We have answered via your parallel support ticket.
pintosal
Post by pintosal » Thu Jul 13, 2017 10:58 am
Many thanks
