SyncBack BETA V7.7.0.0
Post by mickyj » Wed Jun 07, 2017 7:01 am
SyncBack BETA V7.7.0.0 is available for download:
Pro V7: https://www.2brightsparks.com/assets/software/new/SyncBackProV7_Setup.exe
SE V7: https://www.2brightsparks.com/assets/software/new/SyncBackSEV7_Setup.exe
Changes in this version:
New (Pro): New Dropbox API support
New: -eventlog command line parameter
Fixed: Uninstall bug (multiple prompts and access violation)
Fixed (Pro): When editing script it may open wrong script
Fixed (SE/Pro): Folder naming issue with MTP when creating, deleting and renaming folders in browser
Fixed (SE/Pro): Base MTP folder may be wrong
Updated: Fewer uninstall prompts
Updated: The log viewer dialog (when 30 or more log files) now shows if run was a success
Updated (Pro): Warn about Dropbox V1 profiles
