SyncBackSE V8.0.2.0 and V7.6.82.0 BETA
For technical support visit
Postby mickyj » Fri Jun 02, 2017 9:34 am
We've uploaded a beta V8.0.2.0 and V7.6.82.0. For V8, the only change is to fix an uninstalling issue. The V7 beta also fixes this issue. If you've previously installed older versions of SyncBack, and then you uninstall, you may get multiple prompts about keeping your profiles. This beta release fixes this issue.
V8 Beta ... _Setup.exe (32-bit) ... _Setup.exe (64-bit)
V7 Beta ... _Setup.exe
Return to “SyncBackSE (commercial)”
