trying to set file rename on case/properties change for destination backblaze, but the option is greyed out(unsupported)? Backblaze B2 supports this via their api: https://www.backblaze.com/b2/docs/b2_copy_file.html (b2_copy_part for large files), so it could be implemented by copy + delete . Please consider supporting this.
Currently automatic renames/copies attributes to source(undesirable). So i have it on ask for prompt.
