Hi!
It is known that Windows does not support a double quotes in a file name.
SyncBackPro gives an error message: "Failed to copy from Source: Cannot copy file (123)", when
user try to copy the file which name contains double quotes.
As a result the user feels discomfort as it is impossible to synchronize catalogs completely.
If to download the same file by means of Google Chrome, then the file will be loaded.
At the same time double quotes in a name of the file are replaced with single quotes.
Whether it is possible to make in Syncbackpro something similar?
