Portable / no install updates
mattb5906
Knowledgeable
Knowledgeable
Post by mattb5906 »
Portable / no install update prompts should be intelligent enough to link directly to these: http://support.2brightsparks.com/knowle ... age-device
Rather than the installer.
I forgot I was running it portable and accidentality installed it instead.
mattb5906
Knowledgeable
Knowledgeable
Re: Portable / no install updates
Post by mattb5906 »
Thought it had lost all of my profiles, but it was due to SyncBack using the installed version configuration even though I ran the portable version - another bad design.
Mr.X
Post by Mr.X »
Thanks for this info.
