SyncBackPro not creating FTP directories
sellmy300m
Post by sellmy300m » Tue Nov 28, 2017 9:59 pm
I am evaluating SyncBackPro v8.4.5.0 backup running on Win10-64 backing up to a FileZilla 0.9.60 FTP server on Win10-32 using an FTPS connection. At present, I'm on a LAN with no firewall other than Windows firewall. SBP successfully logs in and backups up files into existing folders / dirs, but fails to create directories on the FTP server. Error message:
Scan failed (-1): Expected another server reply(15) : 550 CWD failed. "/ABC/DEF": directory not found.
Step and repeat that message for every directory. There are no other messages, except "skipped" files because the directory doesn't exist. FileZilla logs confirm the 550 failure.
I can connect via an FTP client and successfully create directories without issue.
Does the forward / vs Windows back \ have anything to do with it? If so, is there an option to address the problem?
Thanks in Advance.
SBP Test FTP connection output:
11/28/2017 3:41:43 PM: SyncBackPro V8.4.5.0 (x64)
11/28/2017 3:41:43 PM: Windows 10 x64 build 15063
11/28/2017 3:41:43 PM: Resolving host name "192.168.1.3"
11/28/2017 3:41:43 PM: Connecting to 192.168.1.3 Port: 21
11/28/2017 3:41:43 PM: Connected to 192.168.1.3.
11/28/2017 3:41:43 PM: 220-FileZilla Server 0.9.60 beta
11/28/2017 3:41:43 PM: 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
11/28/2017 3:41:43 PM: 220 Please visit https://filezilla-project.org/
11/28/2017 3:41:43 PM: AUTH TLS
11/28/2017 3:41:43 PM: 234 Using authentication type TLS
11/28/2017 3:41:43 PM: Connected. Exchanging encryption keys...
11/28/2017 3:41:44 PM: Key Exchange: 256 bit Unknown
11/28/2017 3:41:44 PM: Session Cipher: 256 bit AES
11/28/2017 3:41:44 PM: Unknown encrypted session established.
11/28/2017 3:41:44 PM: Command channel protection set to Private.
11/28/2017 3:41:44 PM: PBSZ 0
11/28/2017 3:41:44 PM: 200 PBSZ=0
11/28/2017 3:41:44 PM: USER fxdwg
11/28/2017 3:41:44 PM: 331 Password required for fxdwg
11/28/2017 3:41:44 PM: PASS (hidden)
11/28/2017 3:41:44 PM: 230 Logged on
11/28/2017 3:41:44 PM: SYST
11/28/2017 3:41:44 PM: 215 UNIX emulated by FileZilla
11/28/2017 3:41:44 PM: Detected Server Type: UNIX
11/28/2017 3:41:44 PM: RTT: 5.220 ms
11/28/2017 3:41:44 PM: FEAT
11/28/2017 3:41:44 PM: 211-Features:
11/28/2017 3:41:44 PM: MDTM
11/28/2017 3:41:44 PM: REST STREAM
11/28/2017 3:41:44 PM: SIZE
11/28/2017 3:41:44 PM: MODE Z
11/28/2017 3:41:44 PM: MLST type*;size*;modify*;
11/28/2017 3:41:44 PM: MLSD
11/28/2017 3:41:44 PM: AUTH SSL
11/28/2017 3:41:44 PM: AUTH TLS
11/28/2017 3:41:44 PM: PROT
11/28/2017 3:41:44 PM: UTF8
11/28/2017 3:41:44 PM: CLNT
11/28/2017 3:41:44 PM: MFMT
11/28/2017 3:41:44 PM: EPSV
11/28/2017 3:41:44 PM: EPRT
11/28/2017 3:41:44 PM: 211 End
11/28/2017 3:41:44 PM: CLNT SyncBackPro
11/28/2017 3:41:44 PM: 200 Don't care
11/28/2017 3:41:44 PM: OPTS UTF8 ON
11/28/2017 3:41:44 PM: 202 UTF8 mode is always enabled. No need to send this command.
11/28/2017 3:41:44 PM: PWD
11/28/2017 3:41:44 PM: 257 "/" is current directory.
11/28/2017 3:41:44 PM: CWD /KAL/
11/28/2017 3:41:44 PM: 250 CWD successful. "/KAL" is current directory.
11/28/2017 3:41:44 PM: 257 "/KAL" is current directory.
11/28/2017 3:41:44 PM: Unknown - 215 UNIX emulated by FileZilla
11/28/2017 3:41:44 PM: TYPE I
11/28/2017 3:41:44 PM: 200 Type set to I
11/28/2017 3:41:44 PM: PROT P
11/28/2017 3:41:44 PM: 200 Protection level set to P
11/28/2017 3:41:44 PM: PASV
11/28/2017 3:41:44 PM: 227 Entering Passive Mode (192,168,1,3,39,19)
11/28/2017 3:41:44 PM: Opening data connection to 192.168.1.3 Port: 10003
11/28/2017 3:41:44 PM: STOR SBSE____.YN9
11/28/2017 3:41:44 PM: Connected. Exchanging encryption keys...
11/28/2017 3:41:44 PM: 150 Opening data channel for file upload to server of "/KAL/SBSE____.YN9"
11/28/2017 3:41:44 PM: 4 bytes transferred. (129 bytes/s) (31 ms)
11/28/2017 3:41:48 PM: 226 Successfully transferred "/KAL/SBSE____.YN9"
11/28/2017 3:41:48 PM: MFMT 20171128214144 SBSE____.YN9
11/28/2017 3:41:48 PM: 213 modify=20171128214144; /KAL/SBSE____.YN9
11/28/2017 3:41:48 PM: RNFR SBSE____.YN9
11/28/2017 3:41:48 PM: 350 File exists, ready for destination name.
11/28/2017 3:41:48 PM: RNTO SBSE____.TMQ
11/28/2017 3:41:48 PM: 250 file renamed successfully
11/28/2017 3:41:48 PM: DELE SBSE____.YN9
11/28/2017 3:41:48 PM: 550 File not found
11/28/2017 3:41:48 PM: SIZE SBSE____.YN9
11/28/2017 3:41:48 PM: DELE SBSE____.TMQ
11/28/2017 3:41:48 PM: 250 File deleted successfully
11/28/2017 3:41:48 PM: Features supported by FTP server:
11/28/2017 3:41:48 PM: MODE Z: Yes
11/28/2017 3:41:48 PM: MDTM: Yes
11/28/2017 3:41:48 PM: MFMT: Yes
11/28/2017 3:41:48 PM: MLST: Yes
11/28/2017 3:41:48 PM: SIZE: Yes
11/28/2017 3:41:48 PM: REST: Yes
11/28/2017 3:41:48 PM: XCRC: No
11/28/2017 3:41:48 PM: XMD5: No
11/28/2017 3:41:48 PM: UTF8: Yes
11/28/2017 3:41:48 PM: Passive connection: Yes
11/28/2017 3:41:48 PM: Can set file last modification date and time: Yes
11/28/2017 3:41:48 PM: Can set file creation date and time: No
11/28/2017 3:41:48 PM: Supports safe copies: Yes
11/28/2017 3:41:48 PM: Supports resuming: Yes
11/28/2017 3:41:48 PM: Supports file hashing: No
11/28/2017 3:41:48 PM: Supports Unicode (UTF8): Yes
11/28/2017 3:41:48 PM: Supports faster directory listings: Yes
Re: SyncBackPro not creating FTP directories
Post by Swapna » Wed Nov 29, 2017 6:24 am
Please submit a support zip (with debug logs) of your profile run to support@2brightsparks.com for investigation.
