Filename-encryption + disconnects
loosa2
Post by loosa2 » Sun Nov 19, 2017 12:30 am
Hello Gentlemen,
I am planning tu use filename-encryption for doing a backup of a 150 GB dataset to a network drive, which is accessed through internet. Filename-encryption with your program is only possible through merging the whole dataset into one zip-file, which is basically a nice and clear principle. But, my testruns unveiled, that a connectivity interruption willl corrupt the whole zip-file, no matter if its being created or updated. Im pretty sure i can do circumvent this issue for the initial upload by creating the zip-file locally and then upload it, change the target of the encryption job and be done. But the issue then remains for the updating process.
For uploads without filename-encryption, resuming after disconnect seems to be no problem, so i hope there is some solution.
If this issue is unsolvable, do you have any workarounds?
Thanks, Fabian
loosa2
Re: Filename-encryption + disconnects
Post by loosa2 » Sun Nov 19, 2017 11:09 am
Some follow-up:
Even if i cancel the uploading process manually by pressing the stop button, the file will get corrupted. I dont think this is the expected behaviour. Error message is in all cases: "Central directory locator corrupted or not found"
Post by Swapna » Mon Nov 20, 2017 12:35 am
Please submit a support zip (with debug logs) of your profile run for investigation.
