Local OneDrive files are not backuped anymore
AddyKoster
Post by AddyKoster » Wed Nov 15, 2017 9:34 pm
The local OneDrive files and directories are not found anymore by SyncBackPro and all files/directories are removed from my backup. Until recently I had no problems making a backup from the local OneDrive. I use the latest version of SyncBackPro on Windows10. Who can help me?
Re: Local OneDrive files are not backuped anymore
Post by Swapna » Thu Nov 16, 2017 4:00 am
Please upgrade to the latest version of SyncBackPro from here:
https://www.2brightsparks.com/downloads.html
and un-tick the option "Ignore NTFS junction points (reparse points)" from:
Modify profile > Expert > Compare Options > Attribute settings page
and re-run the profile to see if it helps?
Please refer to this form post for additional details:
viewtopic.php?t=13137&p=49706#p49706
AddyKoster
Post by AddyKoster » Fri Nov 17, 2017 7:47 pm
Thanks, problem solved..!
