Feature Request: Option to raise FTP copying threads
mgutt
Knowledgeable
Knowledgeable
Post by mgutt » Mon Nov 13, 2017 2:21 pm
My ftp target seems to have some problems and disconnects every 5 to 20 copied files. I tested it with filezilla and I have the same problem there. So it must be a problem with my server. In Filezilla I can easily raise the parallel threads and by that it copies with 90% of the threads while the others try to reconnect, but in SyncBack it pauses for 5 seconds before resuming the sync process. Of course I can reduce the "Seconds Between Attempts" setting to 0 seconds, but it is still much slower than it would be with parallel copying threads.
Conclusion: It would be nice to be able to edit the "copying threads" in addition to the existing "scan threads" setting.
Re: Feature Request: Option to raise FTP copying threads
Post by Swapna » Tue Nov 14, 2017 2:10 am
Thank you. I will pass your request to the development department for their consideration.
