Is there a status/test setting to see if SyncBack copies locked files?
mgutt
Knowledgeable
Knowledgeable
Post by mgutt » Mon Nov 13, 2017 1:04 pm
I like to be sure that SyncBack copies locked files. Is there a status info anywhere?
Re: Is there a status/test setting to see if SyncBack copies locked files?
Post by Swapna » Tue Nov 14, 2017 1:08 am
The ‘Copied, deleted, renamed, and changed’ section of the log file shows the list of files that are copied during a profile run. Sorry, but there is no indication on whether a file is a locked file or not. However, if you know the full path of a locked file then you can search for it in the ‘Copy/delete…’ section (or Error section) of the log file to view the status of that file.
To view the log file (after the profile run): select the profile from SyncBackPro’s main-window > right click and select View Log > Newest from the pop-up menu.
mgutt
Knowledgeable
Knowledgeable
Post by mgutt » Tue Nov 14, 2017 8:55 am
Is there a default windows file that is locked all the time? Or can I lock a file like that to test it:
https://superuser.com/a/649819/129262
Code: Select all
notepad >filetolock
