Not a valid timestamp
amartinez
Postby amartinez » Tue Oct 31, 2017 9:47 am
Hi..
We ran a job over the weekend with about 30 files being uploaded successfully to AWS s3
The one error we got was:
"Failed to copy from source: '-1036312348.37119000’ is not a valid timestamp"
Sent 28/10/2017 )6:01:51: POST filename?uploads HTTP/1.1
Can you explain how this odd timestamp slipped in and what we can do to mitigate against this happening ? We want to use this profile to backup our fileserver every two days
Re: Not a valid timestamp
Postby Kostas » Tue Oct 31, 2017 11:29 am
Which version of SyncBackPro are you using?
amartinez
Postby amartinez » Tue Oct 31, 2017 11:39 am
Hi ...
We are using V8.3.6.8 64bit
on
Windows 2008r2 x64 SP1 build 7601
Postby Kostas » Tue Oct 31, 2017 11:46 am
Try this beta version of SyncBackPro V8:
Install it over-the-top of your existing installation so it can preserve your current profiles and settings.
If you are still getting the error with the beta then please generate a Support Zip with debug logs for your profile and send it over to us for further investigation.
amartinez
Postby amartinez » Tue Oct 31, 2017 12:05 pm
Firstly we are trying the profile run again in normal mode with the current version. This is taking 8 hrs in total with about 3 used already
If the same error appears we will run in debug mode
But is there any reason why a strange timestamp would appear like that?
We do a daily backup in another environment V8.3.6 32bit and that's been running no problems for several months.
Users browsing this forum: Google [Bot] and 4 guests
