Not deleting per settings
LaryW
Knowledgeable
Knowledgeable
Postby LaryW » Sun Oct 29, 2017 5:05 pm
I have a profile that compares folders on my computer to external hard drive. If it doesn't find a file on the the internal drive E then it should delete if found on external drive J. However for some reason it isn't working. When I run the profile it shows no files to delete but when I look at the folder on the external there are some files but none in the corresponding folder on the computer.
Win 10, SB Pro 8.3.6.0
Have I missed a setting somewhere?
Here's a screenshot of my settings
Re: Not deleting per settings
Postby Swapna » Sun Oct 29, 2017 11:48 pm
Please submit a support zip with debug logs of the scan phase for further investigation. Enable the option 'Output debug information' from Preferences menu and run the profile in manual mode (ctrl + R). When the Differences Window is displayed, abort the profile run and submit the support zip as per the instructions given here:
LaryW
Knowledgeable
Knowledgeable
Postby LaryW » Mon Oct 30, 2017 4:26 am
Thank you. Just emailed log.
