Problems with SFTP connection
danif_de
Post by danif_de » Mon Oct 23, 2017 12:55 pm
we some have some Problems with a sftp-connection, like this:
23.10.2017 14:47:32: SyncBackPro V8.3.6.0 (x64)
23.10.2017 14:47:32: Windows 2016 x64 build 14393
23.10.2017 14:47:32: Resolving host name "sap-test.xxxxxx.info"
23.10.2017 14:47:32: Connecting to 134.xxx.xxx.86 Port: 22
23.10.2017 14:47:32: SSH-2.0-OpenSSH_7.5p1-hpn14v12
23.10.2017 14:47:32: Starting SSH session. Remote Id: "SSH-2.0-OpenSSH_7.5p1-hpn14v12"
23.10.2017 14:47:32: SSH protocol version reply. Client Id: "SSH-2.0-SmartFTP"
23.10.2017 14:47:32: Key exchange failed.
23.10.2017 14:47:32: Client closed the connection.
23.10.2017 14:47:32: Resolving host name "sap-test.xxxxxxx.info"
I think this SFTP uses newer algorythm to crypt and decrypt than yours in the syncback.
The Connection with this SFTP-Server on the same Server works with the programs filezilla or winscp.
Is there any update for the decryption algorythms in the near future?
Daniel
Re: Problems with SFTP connection
Post by Swapna » Tue Oct 24, 2017 7:52 am
Can you please enable the option "Use alternative SFTP component (usually faster)" under:
Modify > Expert > FTP settings page
and test the connection to see if it helps?
danif_de
Post by danif_de » Wed Oct 25, 2017 11:17 am
i enable the Option but it doesn´t work.
Sorry no improvement.
Post by Swapna » Thu Oct 26, 2017 12:13 am
Please submit a support zip with debug logs for investigation. Full instructions for creating and submitting the support zip are given here:
danif_de
Post by danif_de » Thu Oct 26, 2017 4:59 am
i submit a Support zip with your Support contact page. Another tool thats works with this SFTP-Connection debug this:
Trace: CSftpConnectOpData::ParseResponse() in state 0
Trace: CControlSocket::SendNextCommand()
Trace: CSftpConnectOpData::Send() in state 3
Command: open "248932xxxxxxxxxxx@xxxxxxxxxx.info" 22
Trace: Connecting to 134.xxx.xxxx.86 port 22
Trace: We claim version: SSH-2.0-FileZilla_3.27.1
Trace: Server version: SSH-2.0-OpenSSH_7.5p1-hpn14v12
Trace: Using SSH protocol version 2
Trace: Doing ECDH key exchange with curve Curve25519 and hash SHA-256
Trace: Host key fingerprint is:
Trace: ssh-rsa 2048 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxVucTC+bLgG+T+GIjGB4=
Trace: Initialised AES-256 GCM client->server encryption
Trace: Initialised AES256 GCM client->server MAC algorithm (in ETM mode) (required by cipher)
Trace: Initialised AES-256 GCM server->client encryption
Trace: Initialised AES256 GCM server->client MAC algorithm (in ETM mode) (required by cipher)
Trace: Attempting keyboard-interactive authentication
Trace: Using keyboard-interactive authentication. inst_len: 0, num_prompts: 1
Command: Pass: ************
Trace: Access granted
Trace: Opening session as main channel
Trace: Opened main channel
Trace: Started a shell/command
Status: Connected to sap-live.tritec.info
Trace: CSftpConnectOpData::ParseResponse() in state 3
Trace: CControlSocket::ResetOperation(0)
Trace: CSftpConnectOpData::Reset(0) in state 3
Trace: CFileZillaEnginePrivate::ResetOperation(0)
Status: Retrieving directory listing...
Trace: CSftpListOpData::Send() in state 0
Trace: CSftpChangeDirOpData::Send() in state 0
Trace: CSftpChangeDirOpData::Send() in state 1
Command: pwd
Response: Current directory is: "/"
Trace: CSftpChangeDirOpData::ParseResponse() in state 1
Trace: CControlSocket::ParseSubcommandResult(0)
Trace: CSftpListOpData::SubcommandResult() in state 1
Trace: CSftpListOpData::Send() in state 2
Status: Directory listing of "/" successful
Maybe this helps us to solve the Problem.
