Backup to cloud with limited file size
hallmarc
Post by hallmarc » Tue Oct 17, 2017 8:23 am
Perhaps this is a feature request or perhaps I just haven't found a way to yet work it out.
I'm backing up to unlimited storage in the cloud but I am still subject to a 250MB per-file maximum. Many of my home videos range into the 1+ GB range. I was hoping that I could use the compression option to split large files but apparently that option is only available if I wish to backup all source files in one large multi-part zip. This doesn't allow for efficient backup of modified files. It would be great if I had the option to zip-split (actually without compression) any file that exceeds my cloud storage file size limits.
If this is not an option anytime soon, does anyone have a suggestion as to how I might do this?
Thanks.
