Access Denied Trying to Edit Schedule After Creation
Aceman
Post by Aceman » Mon Oct 16, 2017 11:30 pm
Ok--so I am running a schedule on a user profile that does not have administrator rights but has access to the files needed to a backup. I create a schedule then edit task schedule to check "run with highest privileges. Once I do that I can not longer edit the schedule it tells me that access is denied. Obviously there must be a folder somewhere I need to give the user privileges for. Any clue which one? The use has privileges to the Task folder in the Windows folder so that's not it. Any idea which folder?
Re: Access Denied Trying to Edit Schedule After Creation
Post by Swapna » Tue Oct 17, 2017 5:00 am
Can you please ensure the user account has the necessary Windows user rights as explained in the “User Rights” section of this KB article:
http://support.2brightsparks.com/knowle ... uler-fails
Aceman
Post by Aceman » Tue Oct 17, 2017 9:39 am
Yes the user has the necessary rights and I realized that the profiles are running just not showing up on the main screen. I'll start another thread because I don't really need to run then with highest privileges.
