what does Cannot move file (123) mean?
bess233
Post by bess233 » Sat Sep 16, 2017 9:38 am
Hello,as below,does error 123 mean the path too long?or because some specific words included?
上午 12:46:50 \WORK(O)\04.管理處資料夾\01.財會部資料夾\財會部-專用資料夾\100.內部控制\內控制度辦法_福建達邦\用印資料\Team+\20170906-5 分部工程质量验收记录1分部工程质量验收记录地基与基础2无支护土方子分部工程质量验收记录表10~13轴基础3子分部工程质量验收记录1#仓库地基4混凝土基础子分部工程质量验收记录表10~13轴混凝土基础.jpg
Failed to copy from 來源 : Safe copy failed. Failed to rename temp file: Cannot move file (123): 檔案名稱、目錄名稱或磁碟區標籤語法錯誤。
Re: what does Cannot move file (123) mean?
Post by Swapna » Sat Sep 16, 2017 11:24 am
Please note that the error message
Failed to copy from Source : Safe copy failed. Failed to rename temp file: Cannot move file (123)……”
is returned from your Windows (not from SyncBackPro). Our program is just reporting the error back to the user. You can refer to this link for Windows error codes and search for 123:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
Yes, the error could be due to long file name. Can you try copying the error file manually via File Explorer (or Windows Explorer) from the profile’s source to destination and see if it works?
If it works during manually copy then submit a support zip to [email protected] for investigation. Full instructions are given here:
If your Zip is over 30 MB, contact us for alternate instructions, advising the actual size. Do not try to attach to the ticket!
bess233
Post by bess233 » Thu Oct 05, 2017 3:03 am
Hello,if we have 50 files meet error 123,how will we ignore these 50 files quickly?
Post by Swapna » Thu Oct 05, 2017 7:50 am
Can you please send the support zip to [email protected], so that we can look into your issue and suggest further on your problem?
