Failed to change modification date-time: Cannot change modification date-time
markbelli
Knowledgeable
Knowledgeable
Post by markbelli » Mon Sep 11, 2017 4:48 pm
I have a profile that saves data to a ssh server on the phone.
It always syncs fine, except the google chrome profile folder.
All the files there give this error.
Any idea why?
Thanks!
Code: Select all
I:Uploading file to "/storage/3162-6232/Android/data/com.icecoldapps.sshserver/b/AppData/Local/Google/Chrome/User Data/Default/SBZ!190000M170909150438.Web Data.zipx".
I:Restarting at 0.
I:108072 bytes transferred. (1.15 MB/s) (89 ms)
I:File successfully transferred.
I:Setting attributes of "/storage/3162-6232/Android/data/com.icecoldapps.sshserver/b/AppData/Local/Google/Chrome/User Data/Default/SBZ!190000M170909150438.Web Data.zipx".
I:Attributes successfully set.
I:Removing file "/storage/3162-6232/Android/data/com.icecoldapps.sshserver/b/AppData/Local/Google/Chrome/User Data/Default/SBZ!188000M170905181405.Web Data.zipx".
I:File successfully removed.
Re: Failed to change modification date-time: Cannot change modification date-time
Post by Swapna » Tue Sep 12, 2017 4:07 am
Please submit a support zip (with debug logs) of the profile run for further investigation.
If your Zip is over 30 MB, contact us for alternate instructions, advising the actual size. Do not try to attach to the ticket!
BinaryTB
Post by BinaryTB » Fri Sep 15, 2017 11:36 pm
Same issue. Saving from my PC to SFTP, all zipped (Deflated, lowest comp) with no encryption. I get "Failed to change modification date-time: Cannot change modification date-time" time-to-time with some files. I've noticed that it's only happening with files that are 0 byte on the PC.
Post by Swapna » Sat Sep 16, 2017 11:09 am
As requested in my previous post, please submit a support zip with debug logs to support@2BrightSparks.com for investigation.
BinaryTB
Post by BinaryTB » Thu Sep 21, 2017 2:22 am
I set it to skip 0 byte files. Issue hasn't reoccurred since, no debug logs.
