AWS S3 Mirror Empty Files
Stupotseb1
Post by Stupotseb1 » Mon Sep 11, 2017 3:09 pm
We use Syncback (up to date Vn7) to mirror files from a S3 bucket to a local drive every 5 minutes. Occasionally a file gets copied to the local drive recorded as zero bytes. The files exists as the correct size in the S3 bucket but even if I delete the file locally, syncback never picks up the file again. I have to manually copy it over.
I have verify options ticked but I wonder i these do anything with S3 buckets?
Any thoughts greatly appreciated.
Stuart
Re: AWS S3 Mirror Empty Files
Post by Swapna » Tue Sep 12, 2017 4:09 am
Please submit a support zip (with debug logs) of the profile run, and the full path of the file that SyncBack failed to download for further investigation.
Stupotseb1
Post by Stupotseb1 » Tue Sep 12, 2017 10:05 am
I will post it here the next time it happens with that info.
thanks
Stuart
Post by Swapna » Tue Sep 12, 2017 10:19 am
If the problem occurs again, please submit your support zip to [email protected]. Please do not post support zips on this open forum.
Thank you for your understanding.
Stupotseb1
Post by Stupotseb1 » Tue Sep 26, 2017 8:21 am
I discovered what the issue was. The disk space was too low at times to copy the file so it would copy it with 0 bytes. Older files would get cleaned up and subsequent files would be ok. I increased the disk size and I've not had a problem since.
What is odd though, is that once the file has copied to the local disk at 0 bytes, even if I delete it, it will not mirror and copy that file again. I have to do it manually.
